mvvs 58 problem
hi,
i have an mvvs 58 and the black fuel inlet into the carb is blocking the access to the throttle arm. how can i change the position of the fuel inlet a couple of degress. ive tied gently turning it but it wont budge. thanks for any help. aerowiz |
RE: mvvs 58 problem
...Wiz,
It would be helpful if you take a couple of digi-photos and post them here. Most gas engine users would use, or fabricate a bell-crank, that would operate the throttle arm from a more accessible direction. |
RE: mvvs 58 problem
Dar is correct, look at the layout in this picture. It is easy to operate the throttle pushrod with a bellcrank
RE: mvvs 58 problem
guys
i have built several gassers in my time and have never had to rely on a bellcrank to operate a throttle. this is my first mvvs and it seems to haunt this carby linkage setup. i have always operated on the thinking that keep it simple routine and throwing a bellcrank in there is someting else to go wrong. call me a weirdo if you will but i dont want a bellcrank to fail on my throttle linkage when i am torque rolling at 3 feet. just my opinion. when i work out a way for a straight linkage i will post pictures. aerowiz |
RE: mvvs 58 problem
It is sound engineering to keep parts count as low as possible, and thus keep Murphy at bay. Nothing weird about that.
Please do post a picture when you are done. |
RE: mvvs 58 problem
well guys,
i have sorted out the whole linkage thing. it wasnt as hard as i first thought. egg on my face. the 58 is a real gem of an engine. i cant understand why it took me soooo long to buy one. outstanding performance. when its run in i will post figures. i used to be a da man! roll on the mvvs 116 twin aerowiz |
RE: mvvs 58 problem
Pictures! make us crazy with pictures please.
RE: mvvs 58 problem
1 Attachment(s)
hey guys,
here are a few pictures. aerowiz |
RE: mvvs 58 problem
Looking good.
todo: - fix those rod guide ends to the engine pod, so you will get precise lever movements - Isolate the muffler heat from any tubing that runs near it - Isolate the ignition from the engine heat, and provide for some cool air around that critical component. |
| All times are GMT -8. The time now is 04:58 AM. |
