RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   vlach ignition and li.po. (https://www.rcuniverse.com/forum/mvvs-support-322/3500764-vlach-ignition-li-po.html)
ampa 10-29-2005 04:16 AM
the vlach igniton supplied with mvvs engines can be feeded with two li.po. in series( 7.4 v) without regulator or the voltage is too high?
DarZeelon 10-29-2005 05:14 AM
RE: vlach ignition and li.po.
Paolo,
The Vlach ignition system that comes with all MVVS spark ignition engines, is designed to use 4.8-6V nominal voltage.
This means you can use either a 4-cell or a 5-cell Ni-Cd, or Ni-MH pack.
Using the 7.4V two-cell Li-Po, directly would shorten the life of the system, as well as voiding its warranty.
If you use Ni-MH, a 4 cell pack of AAA batteries would be light enough and offer sufficient flying time.
Don't risk using Li-Po directly.
ampa 10-30-2005 04:25 AM
thanks
