RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   Evolution/MVVS 45gx2 Oil (https://www.rcuniverse.com/forum/mvvs-support-322/7038817-evolution-mvvs-45gx2-oil.html)
ggroyal1 02-07-2008 01:15 PM
I have been using Mobil 1 Racing 2T fully synthetic 2 cycle oil at 40:1 mix with 93 octane(always fresh from the pump) on my 45gx2 in a H9 Cap232g and 22x8 prop. It has been running and cranking without any problems for almost 2 years.
Mobil 1 has discontinued the oil. I was going to stock up, but it has a 1 year shelf life. Can I use Amsoil 100:1 (used in DA50 engines)? Is there another brand available in the USA that would replaced Mobil 1? Mobile 1 said they do not plan to make a replacement.
George G. Royal
janch 02-07-2008 02:14 PM
RE: Evolution/MVVS 45gx2 Oil
You can use
High quality full synthetic two stroke oil
pe reivers 02-07-2008 06:20 PM
I am currently investigating Putoline to stock as replacement oil. You need a SAE 50 weight oil in the MVVS engines.
Do not think lightly about it if an engine churns out about 17 horses per liter per 1000 rpm on a cantilever crank construction. DA is'nt even close to that.
PS shelf life is not to be overrated. You can easily store a jug of oil for two years.
wifpwcf 02-07-2008 08:49 PM
hi i use motol 800 in my mvvs motors great oil
cheers glen
pe reivers 02-09-2008 07:49 AM
yes it is one of the oils that MVVS has approved
