Manuals for Nitromodels
#51
RE: Manuals for Nitromodels
John,
Thank you for for the manual!
One question. I understand the 4 holes in the wings and the poles that go through the fuselage but how do the wings actually attach? There doesn't seem to be a step for fastening the wings on.
Thanks again.
Thanks again.
#52
QC, CANADA
Sorry, the cg range and control surface deflections I need are for the Extra 330L 50 - 80" ARF:
http://www.nitroplanes.com/ex335080arfe.html
If you have a manual, please email to [email protected]. Thanks.
ORIGINAL: nitrostaff1
can you please om me which item you have directly from my website?
John
Nitro Planes
John
Nitro Planes
ORIGINAL: CDN-uavpilot
Hello,
I am looking for the recommended cg range and control surface throws for the Extra 330L. Thanks.
Frank
Hello,
Frank
#53
John, i bought a p40e warhawk the 53.5 " wingspan a while ago . just now getting around to building it . upon opening it i found that the instruction manual is not in the box. i have bought other planes from nitro and all had manuals. but not this one. could i get one sent to my email address. its [email protected] thanks hope to hear from ya soon. and its the plane that was revied in model airplane news sometime ago. am looking forward to building it as soon as i can gety a manual. thanks Don
#54
CA
I'm in the process of getting the manual. I'll email you once we have it.
John
Nitro Planes
John
Nitro Planes
John
Nitro Planes
John
Nitro Planes
Hello,
Frank
Hello,
Frank
#55
CA
Please see here: http://www.quickworldwide.com/P40_50Warhawk.pdf
John
Nitro Planes
John
Nitro Planes
ORIGINAL: nbl_2105
#56
hello john i bought the ultimate 120 biplane from nitro planes and the build mauual isnt clear at all on how to build this plane. i sent an email to nitroploanes and they told me to contact rcuniverse for advise on how to build this plane. so far no reply from anyone. can you get a better manual for this plane or am i stuck with the one i have.
thanks david long kerrville tx. [email protected]
#57
David what problem are you having?
For the most part I found this plane to be a very easy and somewhat intuitive build, but I could see that a few things may be confusing if you are not used to building a number of ARF's prior to this plane.
#58
My Feedback: (8)
NV
John
The 'manual' for the Ultimate 55" I orderd and recieved does not give the location of the wing strut mounting blocks![] I hate poking around with a pin to find them.[&o] Please help![8D]
[email protected]
AMA129570
[email protected]
AMA129570
#59
CA
Manual sent.
John
Nitro Planes
John
Nitro Planes
ORIGINAL: david long
#60
CA
Manual sent.
John
Nitro Planes
John
Nitro Planes
ORIGINAL: ZebraOne
John
[email protected]
AMA129570
John
[email protected]
AMA129570
#62
Moderator
Was contacted by John after posting with a promise to scan and send a manual. Haven't heard anything since. Seems that a manufacturer should have all their manuals in electronic form these days anyway. It shouldn't be this hard to email a PDF file.
#63
Moderator
I recieved a scanned set of images of the manual the day after the last post. John's working hard to keep our needs met. He scanned this for me and sent it out at no charge, even though I am not the orignal owner of this plane and have never bought anything from Nitromodels. Thanks!
#64
Hi John, could you please kindly send me a copy of manual for 71" B25 to [email protected]?
Thank you.
Thank you.
#65
Hello,
I just picked up a Katana-S 140, is there an online manual for it?
http://www.nitroplanes.com/cmpka14072al.html
If not would you be able to send me one?
Thank you,
Mike
[email protected]
Thank you,
Mike
[email protected]
#66
CA
check your email.
John
Nitro Planes
John
Nitro Planes
ORIGINAL: jonathon bai
Thank you.
Thank you.
#67
CA
ORIGINAL: mikeb99
Hello,
Thank you,
Mike
[email protected]
Hello,
Thank you,
Mike
[email protected]
John
Nitro Planes
#69
My Feedback: (69)
Hi, Doing a repair for some one and they lost the manual for it it's mitsubisi A6M5 50 zero could you help with the CG location please thank's Chick.
e-mail - [email protected]
#70
I was wondering if i could get a copy of the 63" predator manual e-mailed to me @ [email protected]... Thank you... I do not have an order number because i purchased my plane off of ebay. thanks for youe help.
#71
My Feedback: (205)
MI
John, thanks for getting back with me on the cg for your Kantana 50cc...137 MM back from the leading edge...now one question in using that measurement...is that back from the leading edge at the tip of the wing or at the wing root...with the leading edge sweeping back like it does, if that is at the tip then I would have to add in the sweep distance to get the proper measurement at the wing root... 137mm is 5.3" and if one would have to add in the sweep that addes up to around 7.5-8" at the wing root. Thanks ahead of time for all your help...it's appreciated on this end ....Rlg...
#72
CA
#73
Can I get a PDF copy of the Low Wing Aerobatic Trainer 60 manual? Email is [email protected]. Much Appreciated!
Taylor Kitchens
Taylor Kitchens
#75
My Feedback: (58)
NC
John, I need the programming beep codes for a 30A ESC for my L-39. I have have some how changed it. Please send codes or tell me the manufacture and modle number and I will try to find myself..
