NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Bob cat
Old 08-06-2007 | 12:04 PM
Default Bob cat
When mounting the eng. do you need too off the eng. or is built in?
Old 08-06-2007 | 12:06 PM
opjose's Avatar
Default RE: Bob cat
I don't quite understand your question.
Are you referring to the down/up thrust? If so it's built in.
Old 08-06-2007 | 12:52 PM
Default RE: Bob cat
I`m sorry , what i was trying too ask do you need need too off set the eng. any degrees for eng. thrust.
Old 08-06-2007 | 01:02 PM
opjose's Avatar
Default RE: Bob cat
Do you mean for Up/Down thrust?
If so, no. It's built in.
Since it's a pusher prop plane, there is also less of a "P Factor" effect for right thrust too, so get the engine lined up as straight as you can.
Old 08-06-2007 | 01:17 PM
Default RE: Bob cat
Thanks opjose
By the way would you know anything about the landing gear being weak? And what would be a good replacement set ?
Old 08-06-2007 | 02:05 PM
opjose's Avatar
Default RE: Bob cat
IMHO they are not overly weak.
However they do not fair very well on hard landings and stiffer gear may do better UP TO A POINT...
( I would rather have the gear "give" then have the wing or fuselage damage. ).
I put in Robart 510W retracts in mine and these have fairly thick wire.
If you choose to go with the stock gear one simple solution is to solder a piece of re-inforcing wire as a cross brace... much like you would put in a tail support strut.
