NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Ultimate 120
Old 05-20-2008 | 01:34 AM
Default RE: Ultimate 120
Thank you guys !!!
First I have to finish the Dragon Lady 90-120 from ModelTech and Spitfire (2030mm wingsp and 1.80 FS from Hot-hobby.com), I must do it for my reach friend, but now I can order the OS 1.20FS
Best regards
Peter
Old 05-20-2008 | 07:00 PM
Rod,
That is good news about you 120 Ultimate. I have one also. I just started putting it together. I'm putting a 26cc gas engine in mine. I always wanted a plane that can go vertical all the way and I'm sure this combo will do it. Will post pictures when I finish it. I don't have the wheel pants, not in box. Hopefully NitroPlanes will send me a set. Happy flying.
Al
Old 05-20-2008 | 07:16 PM
I am putting a XYZ 26cc gas engine in my 12 Ultimate. I do believe it should be ok since you have a BME 26cc that worked out great for you. I should have mine ready in June.
Al
Old 05-20-2008 | 07:20 PM
RR24,
Who was the manufacturer of your engine? I'm putting a XYZ 26cc in my Ultimate. I hope I have plenty of power. What prop did you put on the engine?
Al
Old 05-20-2008 | 09:50 PM
RR24's Avatar
I have the SPE-BCMA 26cc, i think it is simular to your, i had a 17x8 and 17x6 on it, didnt like the 17x6, was better with the 17x8
Old 08-05-2008 | 03:32 PM
  #31
After reading the positive posts about this plane, I placed my order this morning for one. I've got an MVVS 26cc that I plan to put on it; and then shorten the tuned pipe so I can use an APC 16x8 prop. Hopefully, I can get it together quickly after it arrives and get in some great flying time in late August or early September.
Thanks for the informative posts.
Steve
Old 08-08-2008 | 07:39 PM
  #32
RR24's Avatar
Good luck, i think you will like it
