NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
A-10 Warthog
Old 05-26-2008 | 06:00 PM
Default A-10 Warthog
A-10 took it to the field today,what an experance! touch the sticks and wo touchy. But the real problum it was cuting out in flight,landing was ok,inspecting motors and fans. Turned on motors for a listen bad news left motor fan rubing on housing,feels like its going to vibrate apart,shut down quick. Help!
Old 05-27-2008 | 06:13 PM
fcomer84's Avatar
Default RE: A-10 Warthog
Mine did everything yours has done! As it barely flew away it began to cut out, then when I got it closer it ran smooth. The radio is weak. Did not do it with a ground check.
Look for a small rock or dirt or grass between the fan and housing.
Old 05-27-2008 | 08:53 PM
Called Nitro sending it back refund ya
Old 05-28-2008 | 01:01 PM
opjose's Avatar
ORIGINAL: Jerrybl
This is pretty normal for small electric DF fans.
You have to "break in" the engine first.
Most DF's require that you run the engine at varying speeds for 5-20 minutes to remove any burrs or flashing from the props.
You can help this process by carefully doing this yourself with a small nail file.
Pulling out the prop and balancing it is also a great idea too.
Cutting out of the ESC indicates that the battery has hit the LVC point or is overheating.
Either it was not charged fully, or you flew too long, or the battery is bad, or the fans are drawing too much current ( least likely ).
Old 09-19-2008 | 01:30 PM
Hi!Just a question.I've got the desert one from nitroplanes but want to change for a li-po battery.Can anyone tell me where is the CG on this plane?Can't find it anywhere on the paper that came with the box.Thanks
Old 09-19-2008 | 02:21 PM
ORIGINAL: Jeepman540
I am working with Nitroplanes to assemble a brushless upgrade package.
I found this on the CG:
seems lots of people using the 2 inch measure, you can try and work it out by using some infomation here perhaps http://www.bumpygreen.co.uk/Articles...avity/cofg.htm
Hope it helps...
Lipo battery helps the plane with current motors, but it is still "shaky". Do not expect to fly acro/aero-batics or with great authority through air.
Old 09-19-2008 | 04:08 PM
Thanks a lot,seem a bit complicated to calculate but it is all there.I will study it carefully.I'm only use to do it with a plumb bob when the CG is already mark on the plan.Thanks again very helpfull
