NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
cmp 330l 50cc
Old 09-21-2008 | 08:19 PM
Default cmp 330l 50cc
my wing tube on my 50cc size cmp 330l snaped in half todat on its maiden flight on a verry lo g pull out destroying the plane,brand new da50 3 8411 srevos ,reciver,well everthing
I was concerned about the wing tube because it was paper thin but it came w/ the plane it should of made it through a basic turn . this is bs im out 1000.00 any sugestions????
Old 09-22-2008 | 12:37 PM
opjose's Avatar
Default RE: cmp 330l 50cc
How thick were the walls of the tube?
I've thrown my CMP 50CC Edge around quite hard with the stock tube w/o problems... so I'm curious.
The 330L has a bigger wingspan and probably exerts a higher lever moment against the tube than mine, but the tube should certainly NOT break... ( it should bend first... ).
It sounds like you received a bad tube.
PM John here with this too.
Reference this thread.
Old 09-22-2008 | 05:07 PM
IT was carbin ? looked like it anyway,but paper thin 1/32 ish, but it came w/model so I figured they hade it worked out It must of ben bad or the wrong one but it fit like a glove. I hope N.M.
can do somthing for me
Old 09-22-2008 | 06:43 PM
opjose's Avatar
How about posting a picture with a ruler right up against the edge of the tubing?
It should have been about 1/16" thick.
Old 09-23-2008 | 05:18 PM
il try to get pick up tonight,no way its 1/16
Old 09-24-2008 | 05:01 PM
I measured the wing tube its abt 1/64 thick or.016 th or .042mm
Old 09-24-2008 | 05:02 PM
cant fig how to get picks up they loaded good now what? I got them on my profile
Old 10-27-2008 | 06:28 PM
I can confirm craig's experience. The wing tube is a composite material although not sure exactly what. It is paper thin. I assumed that the supplied tube was able to withstand the loads since it was supplied by the manufacturer even though it did not seem right. The tube snapped just after making a gentle turn after take-off. Destroyed the Zenoah engine. Salvaged rest of the electronics.
The airframe is constructed well. Lots of room to put equipment. Just make sure to replace the wing tube with an aluminum tube.
Old 10-28-2008 | 01:26 PM
opjose's Avatar
Someone else also suggested inserting a strengthening dowel inside the existing tube. Apparently they used dowel stock purchased at a local hardware store.
It may add a little weight but the safety factor improves.
Old 10-28-2008 | 10:16 PM
If you thought it was not right to go with that plane then you should have made changes..when you buy the cheapest plane available,be ready to use some skills to evaluate and adopt the airframe as necessary.
Its how it is these days.You wanna safe a $ you will pay somewhere else..
With experience you can overcome and correct these problems easily.
Old 10-29-2008 | 12:12 AM
opjose's Avatar
Yes to an extent that is certainly true, although you can do well if you know what you are doing....
The less expensive planes do require a bit more TLC and going over, but they still fly well and will hold up if properly constructed.
On the other hand I've purchased more expensive planes and have found them needing the same going over and also requiring a good going over.
Old 02-07-2009 | 11:40 AM
edmoor's Avatar
ok.....is it 1/64th.....or 1/16th?.....do you know how to read a scale?.....big difference between 1/64th and 1/16th dude...like .047"......i woulda never used it....cant always go with comes supplied in a kit....you shoulda known better!!!
