Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
 F/18 RTF Engine help >
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 10-16-2008 | 01:44 PM
Default F/18 RTF Engine help
I've been flying this plane for a while and after I changed the rotation to CCW just for fun I noticed a new nasty bearing noise. I'm wondering,
Where can I get bearings for this engine and also, where can I get a direct replacement engine if needed. Thanks
Old 10-16-2008 | 02:41 PM
opjose's Avatar
Default RE: F/18 RTF Engine help
You can measure the diameter of the can, then substitute any of the same dimension.
If all you did was to reverse the connectors to change directions, this should not affect the bearing.
Spin the prop by hand. Do you feel any grinding or other artifacts?
If not, the motor has probably NOT been damaged.
However running the prop backward may have damaged it SLIGHTLY, causing it to become unbalanced or a blade may have rubbed and ground off a bit.
You should follow EDF engine break in proceedures again. This may fix or eliminate the noise you hear.
