Yak 52 CG question
I bought a Yak 52 3D - 50-56 plane, does anyone know where the CG is on this plane and what the throws should be to start. This stuff was not in the instructions, and I am sure others have set this plane up.
Thank you
Thank you
CG is 120mm from leading edge into the wing.
Alieron +/- 12mm
Rudder +/- 100mm
elevator +/- 40mm
John
Nitro Planes
Alieron +/- 12mm
Rudder +/- 100mm
elevator +/- 40mm
John
Nitro Planes
ORIGINAL: tailer1
Thanks for the help on the CG My order # is
17210252890263-61749
