Nitro Models F 4 Phantom
My Feedback: (10)
Hello,
I recently inherited a Nitro Models F4 Phantom airframe. It is now in rehab. The damage wasn't all that much, it just needs a little work. The problem I am running into is the specifics as to the CG and the throws on the ailerons, rudder and elevator. I do not have the instruction book, that left when the club member moved south to Florida, never to return.
If anyone could help me out with those specifications, I would be grateful.
Also, is there somewhere that I might be able to purchase a new cowl? The previous owner chopped it up pretty badly fitting his motor into it.
Thanks for your help.
JAGMI
JAGMI
My Feedback: (10)
John,
Thanks for the infomation. However I do not have the foam edf Phantom. I have the balsa/covered nitro F4. I believe it is a 40 sized airplane. It is the red, white and blue model and has the name Darling on the fuse.
Jim
Jim
I see you have this plane. http://www.nitroplanes.com/xx.html
what's your email? I can send you a copy of the manual.
John
Nitro Planes
John
Nitro Planes
My Feedback: (10)
John,
Yes, that is the plane I have!
I would greatly appreciate a copy of the manual.
Address is: [email protected]
Thank you,
Jim
Thank you,
Jim
