Nitro Planes New! TT-62 Alekto
#51
My Feedback: (60)
FL
RE: Nitro Planes New! TT-62 Alekto
flyboytha1, I purchased a used TT-62 at a swap meet and I need to know where the CG is located, The plane has retracts and is powered by e-flite 770 KV motors. (power 32's ) I hope they make enoughf power. thanks.
regards: Frank
regards: Frank
#54
Thanks!
About your CG question - the manual says:
"The ideal CG position is 100 mm (3.9")behind the leading edge measured at top wing centre line"
Like much of the manual, this may sound unclear, but there is a picture showing the CG at 85mm of the LE (straight part).
Hope that helps.
Werner
Hope that helps.
Werner
#56
Here is a question for all who have completed the build of the TT-62: turns out that my kit was missing a lot of hardware. Of course it's hard to determine what is missing since there is no list available; so the deficencies reveal themselves as the build progresses. Currently I am stuck with the missing pushrod for the rudder. From what I see: a 30" plastic tube that feeds from the cockpit area to the rudder, I conclude that there ought to be a 36" pushrod in he kit. But we are now into 4 months of back and forth with Nitroplanes who keep sending me all kinds of pushrods sized between 5 and 7" - never a 36", and unfortunately any 36" pushrod I can find in local hobby shops are too thick for the installed tube.
So my question is: am I misguided in assuming that there should be a 36" pushrod for the rudder - am I missing an obvious solution to connect servo and rudder in the TT-62?
Looking forward to finding a way out of this impasse,
Werner
Werner
#57
I didn't bother... I just used a "Gold-N-Rod" type Dubro setup... the one with the yellow outer tube and orange inner pushrod tube.
Why can't you just purchase some Music Wire at your LHS? Normally those displays have every imaginable size... TH also sells it.
#58
What a difference a change in wording can make: I have not been able to find a 36" pushrod for months - now I asked for music wire, and there, they have it.
Brilliant, Opjose - thanks for the suggestion!
The only question that remains: why didn't "they" think of it?
Werner
Werner
#59
Hey I was looking to do some 3D drawings of some of the parts in order to replace them when they broke, namely the ribs. I was wondering if a dimension drawing of the plane exists and if not, does anyone know what the airfoil the plane uses is? Would really appreciate any info.
