Damaged Fuselage
Order # <span class="subject" dojoattachpoint="subjectNode">yhst-17210252890263-93399
www.nitroplanes.com/edfpruc10eld1.html
I received this plane on 9-17-09 and found some problems with the fuselage, the rest of the kit was fine.
1- the fiberglass is not glued to the plywood in a few spots.
2- the servo tray is not aligned properly to the fuselage.
3- defect in fusulage impression/ crack.
This is my first purchase from Nitroplanes, can I return the fuselage for replacement or will I need to return the entire kit?
Please advise
Thank you
Charlie
</span>
Please advise
Thank you
Charlie
</span>
John, I received the new fuselage today 9-29-09. Just want to say "Thanks" for your help and quick response in resolving the problem.
Charlie
Charlie
