Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
 Help needed on difficult part >
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 10-21-2009 | 11:36 AM
Default Help needed on difficult part
I own the "Famous models" Rafale edf jet. I managed to break the steering/rudder servo control arm, and am having no luck tracking down another. I have posted in the "spare parts" request thread, w/ no response as of yet. I have also checked out other vendors of the same plane, but again no dice. Help from anyone is greatly appreciated!
Old 10-21-2009 | 02:32 PM
opjose's Avatar
Default RE: Help needed on difficult part
I've substituted micro control arms from other manufacturers into these RTF planes w/o problems.
I believe the Hextronix Micro servos uses exactly the same arm type but I'm not 100% sure.
Old 10-21-2009 | 03:01 PM
Thanks for the reply! The servos you mentioned are 20 spline, like the ones that came w/ the plane, but I CANNOT find the damned combo arm that I need.
Old 10-21-2009 | 03:09 PM
opjose's Avatar
You can't cut one to suit?
Old 10-21-2009 | 03:32 PM
I considered that, but the arms on the original are of unequal length. The slotted arm that moves the front gear is longer than the arm that moves the rudder wire. I haven't found an equivalent "L" shaped arm to cut up yet. Worst comes to worst, I'll have to re-engineer the rudder/steering control system, so I'm still holding out hope for a replacement.
Old 10-23-2009 | 11:10 PM
As I cannot find a way to delete this thread, Mod please delete. Issue resolved.
