Bipe Ultimate 120
Hello at @ll,
I´m from Germany and own a Ultimate 120 55".
I saw, that model and spare parts ( Cowl) are temporarly sold out.
Is ist possible to order a new cowl from Germany??
How much tim I will have to wait for?
Greets
Arnold
Greets
Arnold
did you order the plane from us? what's your order number? is this http://www.nitroplanes.com/ulbi12055scn.html the plane you have?
Let me know so I can better help you.
John
Nitro Planes
John
Nitro Planes
I was absent for a longer time. Thank for your answer. I bought it used in Germany. It is not the pink version, but the yellow one.
Best regards
Best regards
NY
Nitro,
I have the ultimate 120 55" and I am planning on putting in an XLS 1.20 Two stroke. I plan on side mounting the engine, the manual does not give reference on how to attach the engine mount to the fire wall. I am guessing i just make sure the engine is moved over so the cowl will fit over it? i see the the reference lines, am i to use those for alining the mount?
ORIGINAL: airborne14830
Nitro,
I have the ultimate 120 55'' and I am planning on putting in an XLS 1.20 Two stroke. I plan on side mounting the engine, the manual does not give reference on how to attach the engine mount to the fire wall. I am guessing i just make sure the engine is moved over so the cowl will fit over it? i see the the reference lines, am i to use those for alining the mount?
Nitro,
Sheez... please don't double or triple post.
I already answered you on the other thread.
