Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
 The Giles Alien... >
The Giles Alien...
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
The Giles Alien...
Old 06-14-2010 | 04:24 PM
Cpt Crash's Avatar
My Feedback: (12)
Default The Giles Alien...
Just finished mine; what a sweet bird. It's a bit heavy, but the build is pretty easy and it's a solid flyer. Here's my list of minor stumbling blocks.
One thing that wasn't mentioned at all in the directions is the need for a reversing Y for the elevator servos. I used an MPi miracle Y for the job; it has long leads that obviate the need for servo extensions.
The provided tailwheel assembly was way inadequate for this heavy sled, so I switched to a Chief aircraft CF unit.
I used a Du-Bro anti-vibe mount to settle things down up front.
I switched the hinges for genuine Robart units; much less slop and wiggle. I kept the hinge units with the control horns, used epoxy to ensure a solid bond.
Stock clevises and pushrods replaced with Du-Bro 4-40 rods and Great Planes locking metal clevises.
All in all, very minor stuff to do. Otherwise, this is a great airplane.
ID:	1453030   Click image for larger version
ID:	1453031   Click image for larger version
Old 06-16-2010 | 02:07 PM
opjose's Avatar
Default RE: The Giles Alien...
What engine are you using?
Old 06-18-2010 | 02:43 PM
Cpt Crash's Avatar
My Feedback: (12)
I'm using a GMS 1.20 - adequate for sport flying and classic aerobatics. A 1.60 or small gasser would probably be overpowered and fun, but the 1.20 is fine and relatively easy on fuel.
