RCU Forums
-   NitroModels Support (https://www.rcuniverse.com/forum/nitromodels-support-456/)
-   -   Mig15 :-( (https://www.rcuniverse.com/forum/nitromodels-support-456/8887115-mig15.html)
DvirNoiman 06-27-2009 11:06 PM
Mig15 :-(
Hi,
I got the mig15 (the red onw), looks really good. However, after only one flight, the motor does not work.
The speed control light is blinking and it beeps.
Any idea what is going on?
I am very disapointed, hope it can be fic somehow
Dvir
opjose 06-29-2009 11:19 AM
RE: Mig15 :-(
Sounds normal.
Your EsC is not seeing the proper throttle position to arm itwelf.
Try running the throttle up to full and hold it there until the beeps change.
Then bring it all the way down again, including the throttle trim.
DvirNoiman 06-29-2009 12:18 PM
RE: Mig15 :-(
I will try that. I hope that is the case here as well.
Now I can't wait to go home from work, to try that :-)
At any paste, thank you.
I will post again what is the outcome.
Dvir Noiman
opjose 06-29-2009 03:32 PM
RE: Mig15 :-(
Most ESC's have an arming/calibration process and it is likely that is what you are running into.
I assume that the servos do move, however, which verifies that the RX is working properly.
DvirNoiman 06-29-2009 08:29 PM
RE: Mig15 :-(
I am very upset, I tried running the throttle up to full and hold it there until the beeps change.
Nothing was changed. As a matter of fact now there is no sound or light coming from the ESC.
I charged the battery that was included in this RTF, just to be safe. And nothing!!!!
I can control all the surface, but the motor or the esc show no sign of life.
[&o] I am a very unhappy customer right NOW!!!!!
Please help.
Dvir Noiman
(954) 260-6460
opjose 06-29-2009 09:49 PM
RE: Mig15 :-(
You said the "beeps changed" when you ran the throttle all the way up.
This is good. It indicates that the throttle channel is working as is the ESC.
It sounds like everything is working as it should be.
However you have not initialized the ESC, so it is not ARMing properly.
Do this...
0 - Bind your transmitter with your plane all over again.
1 - Turn on the transmitter
2 - Put the throttle TRIM all the way down.
3 - Put the throttle all the way down.
4 - Plug in the plane to it's battery ( turn on the plane ).
5 - Move the throttle all the way up, wait LESS than one second.
6 - Move the throttle all the way down.
DvirNoiman 06-30-2009 08:18 AM
RE: Mig15 :-(
I will try that today, however as I stated in my last post, the esc now shows NO sign of life, no beep or light whats so ever[:o]
I hope your instuction will still work.
Dvir
opjose 06-30-2009 01:05 PM
RE: Mig15 :-(
Try recharging the battery as well. The ESC will not arm or beep if the voltage is too low.... but it still will provide power to the servos.
DvirNoiman 06-30-2009 01:36 PM
RE: Mig15 :-(
That is exactly what is happeneding to me.
The servos work perfectly, but the speed controler does not responds what do ever. I charged the battery to 100% and will try it again today.
I hope it will work :-(
Dvir
DvirNoiman 06-30-2009 06:49 PM
RE: Mig15 :-(
ok, now i extremely frustrated :-(
I just came home and turned on the transmitter and than connected battery (fully charged) to the receiver in the Mig 15.
The receiver light is blinking. and the servos are not responsive. I think I need ti bind it to the transmitter but am not sure how to do that.
Can someone please let me know quick how to bind the RC systems of the Mig 15?
Dvir
DvirNoiman 06-30-2009 07:00 PM
RE: Mig15 :-(
FALSE ALARM!!!! :) a little relief, I bind the transmitter and the receiver successfully , not the servos are reacting accordingly. But still nothing from the motor :-(
DvirNoiman 06-30-2009 07:05 PM
RE: Mig15 :-(
I did exactly that:
and NOTHING !!!!!!!!!!!!!!!!!! the servos works fine! the motor and ESC shows NOTHING!!!!!!
I am in a new level of frustration!!!!!!
[&o]
Dvir Noiman
(954)260-6460
DvirNoiman 07-01-2009 08:44 AM
RE: Mig15 :-(
Here is exactly what is happening with my Mig15 right now.
First, a little background, I had the maiden flight, it flies very well, I flew for 5 minutes and then I felt the airplane has no power so I glided it and run perfectly on the runway.
Afterwards, the motor never worked again.
The same day when I got home, I turn the Tx on, than plugged the Battery. All servos worded fine , the ESC made beep noise at the beginning and was blinking red, you can see the motor is a little bit revolves forward and backwards randomly.
Yesterday I charged the Battery to %100, this time the Tx was not bind to the Rx, I eventually figured out how to re-bind it and again all servos works fine.
But, no movement or light from the ESC or the motor.
I tried to do this process:
But nothing was happening!!!!
BTW, when I plug the battery and the Tx is off, there is a blinking red light from the esc, but no sound at all.
I need help here guys; hope someone can once and for all guide me.
I need to know if I am forgetting to do something, or the maybe the Motor/ESC is faulty.
Thank you
Dvir
opjose 07-01-2009 09:47 AM
RE: Mig15 :-(
The sound actually comes from the motor, not the ESC as the ESC has no mechanism to produce sound directly.
If you are hearing nothing it could also be that the connectors to the motor have become unplugged.
Check these too.
At worst PM John here ( Nitrostaff1 ) and reference this thread.
DvirNoiman 07-01-2009 10:14 AM
RE: Mig15 :-(
It might be the case, that the connectors to the motor have become unplugged, however, the way the Mig15 built, and since it came as an RTF, I can't access the motor or the ESC :-( they located in the middle of the body, between the 2 wings. I will have to cut the airplane in 2, to be able to access them :-(
BTW, thanks for the correction for the source of the beep.
I hope there is a simple solution for that Nitro Support :-(
Dvir
sdjb 07-01-2009 05:39 PM
RE: Mig15 :-(
DvirNoiman, Try this: Turn on the TX put thorttle all the way to full thorttle, Plug in the BAT on the plane, wait for the ESC to Beep[Maybe twice or maybe three times} Put thorttle back to full closed, WAIT for beeps again. Then unplug the plane BAT. Now plug the
plane back in and see what she does now?
sdjb
DvirNoiman 07-01-2009 11:18 PM
RE: Mig15 :-(
Tried what you suggested. No beeps what so ever.
I noticed that there is a blinking light in the esc when the Tx is off, when I turn it on the light disapears.
I disassembled thr Mig15 as you suggested in out phone conversation. (Btw, Spoke with another guy at support, he left you a note to call me back)
I took 3 picture of the Mig , so you can see the Mig-15 with its guts open. All connector look good, but motoe still does not work. NOt sure how to attach it to this post. Maybe I can Email them to you.
John, I am looking forward your call, no one contacted me from NitroModel as promise in various Email.
The long weekend is almost here, and my MIg-15 I got from NitroModels is grounded! [&o]
Dvir
opjose 07-02-2009 10:01 AM
RE: Mig15 :-(
No, do NOT rely upon calls or e-mails.
PM John here ( Nitrostaff1 ) as I mentioned earlier, and reference this thread.
nitrostaff1 07-02-2009 07:09 PM
RE: Mig15 :-(
what's your order number? I'll have you mail be back the ESC and motor for exchange.
John
Nitro Planes
DvirNoiman 07-03-2009 03:50 PM
RE: Mig15 :-(
1 Attachment(s)
My order number is: 589571
Full name is: Dvir Noiman, zip code: 33323
Send the new motor and esc to me asap please. What about the fan unit? are you including that too? (how do you seperate it from the motor anyway?)
The motor and ESC are conected together and wrapped with shrinking plastic.
I hope to get the motor and esc quick.
Dvir
(954-260-6460)
nitrostaff1 07-03-2009 04:21 PM
RE: Mig15 :-(
ok I'll exchange the entire plane for you because this is much better choice. I can not be sure if the new ESC and motor will fix the problem. Instead of keep sending parts I'll exchange the entire plane for you upon return. RMA issued.
John
Nitro Planes
DvirNoiman 07-03-2009 07:54 PM
RE: Mig15 :-(
What is RMA, and what does it mean? how am I going to ship it to you? it is probebly going to cost again at least $20 for me?!
Please let me know. I am waiting to see it fly again, and soon [&o]
Dvir
opjose 07-04-2009 01:41 PM
RE: Mig15 :-(
RMA = Return of Materials Authorization
DvirNoiman 07-04-2009 02:36 PM
RE: Mig15 :-(
Ok, I understand.
How should I sent the airplane back to you?(should I take it a part?) what is the best way to ship it in order to it to be protected in the voyage?
Also, I don't understand, after all the previous frustration you expect me to wait even more, after I have waited without being contacted by nitroplanes as promised!
I believe that if everything, you should sent me the new airplane and only THEN I will send you the one I have in the same package of the new one.
Please honor your sale as I will owner my promise. You must understand that I am growing very impatient and frustrated.
I am a loyal customer of nitroplanes and expected to get what I paid for. I paid already around $20 for shipment of the original order.
I ask for someone to help me here.
Dvir
(954) 260-6460Ok
opjose 07-04-2009 02:52 PM
RE: Mig15 :-(
David he offered to send you a brand new plane upon receipt of the original one.
Threatening, etc. is counter productive and liable to burn your bridge before crossing it. You are already ahead.
Ship it back and get the new one.
Chalk up the delays involved to something that happens now and then. It may be frustrating, but that's how it goes, it's not a big deal, as they ship things out quickly when in stock.
DvirNoiman 07-04-2009 03:13 PM
RE: Mig15 :-(
No threatening here! don't go that route please, as I had no intent to do so. So please leave your Ego aside, i just want to get what i paid for.
How exactly I am going to ship it back if the back wing for instance in glued already?
i don't understand why i simply can't get a working airplane? why should i pay again for shipment? (and by the way, I asked you previously how to sent it back, since I have never shipped something that big and fragile before)
I simply expect for you to handle it professionally.
Dvir
[&o][&o][&o][&o][&o][&o][&o][&o][&o][&o][&o]
opjose 07-04-2009 03:24 PM
RE: Mig15 :-(
Re: Working airplane.
Isn't this eactly what John is trying to do? Get you a working airplane?
All you have to do is pop everything into a box. Since you have already built the plane, it will be a complete loss for Nitroplanes. Remember that when you factor in the shipping cost.
Try to protect it a bit if possible but don't worry too much about it.
John has often asked the sender to merely crack the wings to fit a shipping box.
DvirNoiman 07-04-2009 03:36 PM
RE: Mig15 :-(
Ok, please send me the exact address and what i need to include to make this fast please.
opjose 07-06-2009 11:13 AM
RE: Mig15 :-(
In a prior post John mentioned that he had already issued an RMA for you.
Check your PM's and at worst PM him again.
DvirNoiman 07-14-2009 02:43 PM
RE: Mig15 :-(
Good day, again :D
According to UPS you have recieved my shipping box, so now, I can't wait to get a new WORKING (LOL) Mig-15 back.
You mentioned before that the turn around time is quick, so how long do you think it will take for you to send me a new one? (yes, I am getting excited again here LOL)
Dvir
opjose 07-14-2009 02:45 PM
RE: Mig15 :-(
NP normally turns these around within a day or two.
DvirNoiman 07-14-2009 03:04 PM
RE: Mig15 :-(
Thanks again. :)
Dvir
opjose 07-14-2009 03:18 PM
RE: Mig15 :-(
Let us know when you get the new one.
Do you have a Watt meter BTW?
DvirNoiman 07-14-2009 03:36 PM
RE: Mig15 :-(
Yes, I do. Why?
opjose 07-14-2009 03:39 PM
RE: Mig15 :-(
When you get the new one, check the ESC rating versus the actual draw at full throttle on a freshly charged pack if you would.
I'm curious.
DvirNoiman 07-14-2009 03:45 PM
RE: Mig15 :-(
No problem, I will try that.
Why? what do you think the problem is? too much current maybe? that burned the motor?
Dvir
