O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
46fx breakin
Old 07-31-2003 | 04:01 AM
Default 46fx breakin
Is it true that the manual for th 46fx has the wrong breakin procedure the 10 sec 4cycle 10 sec 2 cycle thing?Does this shorten the life of the engine?
Old 07-31-2003 | 01:16 PM
Bax
For the fuels used in North America, you should use these instructions :
http://www.osengines.com/faq/product-faq.html#q2
The factory-supplied instrucions won't hurt the enginne much, but are more suited for the fuels used in Japan, which have different types of oils, we are told.
Old 08-04-2003 | 12:45 PM
Hello,
I've just discovered OS Fx series are ABN (no longer ABC as with OS SF / FSR series). What's the point ? Is it better ? I doubt it seriously as I continuously see piston/liner troubles with these engines. Is something better planned at OS engines corp ? Back to ABC piston/liners perhaps ? Sad story...
Old 08-04-2003 | 03:09 PM
Won't hurt much?how much? Sad comment that break in instructions are not correct.
