Mufflers for older four-cycles
I have a pair of older OS four-cycle engines that I plan to use in upcoming antique competitions. They are the FS-60 (open rocker) and the FS-90 (rear rocker) engines.
The rules for the events require mufflers on all engines. Did OS ever make a muffler to fit either of these? If not, do you know of any mufflers for later OS four-cycles that I may be able to adapt for them?
For the initial series of O.S. engines, there were no mufflers made for them. They were considered quiet enough, especially when compared to the howling two-stroke engines of the day. The original FS-91 did have a muffler available for it, but it is no longer available from us or O.S. in Japan. You'd have to locate one from a collector.
