O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS GT33 issues
Old 07-29-2020 | 02:38 PM
My Feedback: (35)
Default OS GT33 issues
I have one and it ran very rich as expected. Killed it a couple of times to see how easy it restarted. It did just fine.
I decided to take the cowl off so I could lean it out a touch.
It has never run again. I have cleaned the carb, replaced the spark plug and got a new ignition. Still nothing.
If I choke it and try to start by hand to many times gas will drip out of the carb and the engine is flooded so its getting fuel.
Next, I tried my starter with the choke open as the directions so to do. Nothing.
I checked the plug and it is sparking. My ignition battery is fully charged and is an A123 6.6 volt 1100 mah which should be good.
LS and HS are 2 turns out like the instructions say to do.
I took off the muffler and gas just poured out of the engine.
I'm Stumped. Thanks for any ideas. Is there a service center I could send it to?
Scott
