O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 25 MAX FP
Old 10-01-2003, 09:23 PM
thepope
Default OS 25 MAX FP
A friend gave me on of these in need of a carb. I got a new carb and would like to know what is a good starting point for the needle valve and air bleed?
Bill
Old 10-02-2003, 10:45 AM
Bax
Default RE: OS 25 MAX FP
Start out with the high-speed needle at 2-1/2 to 3 turns out from closed. Set the air-bleed screw so that it's 1/2-way across the hole. Both of these are starting point. Once the engine's started, advance it to full throttle to get the high-speed needle adjusted, and then work with the air-bleed screw to set the idle. Don't try to idle too slowly, many people make the mistake of thinking that the engine will idle as slowly as larger engines. Anywhere between 2,500-3,000 RPM is considered good for this size engine.
Old 10-02-2003, 08:38 PM
thepope
