O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Question on Post-crash Maintenance
Old 09-21-2004, 03:10 AM
MeanMustang
Default Question on Post-crash Maintenance
Hi Bill,
I fly in a very sandy field and recently had a nose down crash on my plane, which is running an OS46FX. Upon inspection, I noticed that the carb barrel was wide open and had quite a fair bit of sand in it. Besides removing the carb for cleaning, would u recommend that I take the entire engine apart for cleaning, and how do I go about doing this?
Old 09-21-2004, 11:07 AM
Bax
Default RE: Question on Post-crash Maintenance
At the least, you should remove the carb, rear cover, and cylinder head. Use fresh fuel to flush out the engine as much as possible. DON'T turn it over until you've thorougly flushed the engine. Then turn it over very, very slowly, feeling for anything that may want to stop the rotation. If any grit's in the bearing, you'll feel it and not cause damage if you're careful. If you can't flush the grit from the bearing while only the head and rear cover are off, you'll have to do a full teardown.
See Harry Higley's book, "All About Engines" for details on disassembly and reassembly of your engine. There's too much involved for this type of communication. You can order the book through your favorite hobby retailer.
Old 09-22-2004, 03:38 AM
MeanMustang
Thanks! Will get round to doing just that.
