O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
os fs70 timing
Old 11-08-2004 | 01:45 AM
Default os fs70 timing
hi
i have an os 70 four stroke that i changed the bearings on and put it back together but now i notice i dont have the instructions on how to set the timing gear hope you can help thanks in advance
mike
Old 11-08-2004 | 11:43 AM
Bax
Default RE: os fs70 timing
When the piston is at Top Dead Center, a dot on the side of the cam gear will line up with the center of the cam followers and pushrods. It is not at 90-degrees to the crankshaft, but tilted aft.
Old 11-08-2004 | 10:15 PM
hi bill
thanks for the fast response
mike
