O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
46fx-h
Old 09-06-2002 | 07:33 PM
Default 46fx-h
Two months ago, I bought a new Raptor 50 with an OS 46FX-H engine. I have runed the engine with 13 tanks and I am having difficulty with it's mixture.
When the engine is cool, the idle mixture is very reach and the engine often quits after removing the glow plug. After it warms up, the idle becomes somewhat better. The midrange and the high end seems ok at any time. I donīt want to close too much the low end mixture because I am afraid it could lean the midrange also and damage the engine.
I have heard of some mixture problems with this engine or maybe it's not fully broken in yet. I am using Powermaster 15% heli fuel and I believe the throtle and pitch curves are adjusted properly. The carb has "40C" stamped on it's side.
Any suggestions?
Thanks.
Old 09-06-2002 | 07:43 PM
Default 46FX-H
Forgot to tell you that I am using a "Torpeedo Speed HV Muffler (46-50)" and all the fuel lines are new (not the stock ones).
Thanks.
Old 09-06-2002 | 09:08 PM
Default 46fx-h
Caiman, does it have a small #2 stamped on it anywhere (the carb)? where/when did you purchase it?
