OS 25 needs more grunt
G'day to all from down under. I have a Sonic 25 trainer, it has an os max 25 motor (recommended size) onboard but it really struggles to get off the ground and climb. I am flying circuits by my self but am a bit worried about learning to take off the way it is. Is there anything I can do to get that little extra?
I am running 10% nitro and a 9x4 or 9x6 prop.
Thanks in advance
Prboz
Thanks in advance
Prboz
on planes with a little drag such as a trainer I find the 9x5 works the best, A 9x6 works but tends to load up a little and keep the rpm lower and the 9x4 might not be enough pull so I would try the 9x5 or even a 10x4 for extra thrust.
Dauntae
Dauntae
My Feedback: (12)
MO
You also might try a moose can muffler on it it should gain a couple of hundred RPM. I remember seeing the directions for it at this site.
http://spadtothebone.com
I forgot about those, Here is a link to the muffler page http://www.spadtothebone.com/SPAD/Mufflers/
Dauntae
Dauntae
