O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Carb setting on 21RG
Old 10-03-2002 | 03:08 PM
Default Carb setting on 21RG
Hi, I have just brought a model that has a new 21RG engine that needs to be run in the manual shows the needle setting of 3 turns but nothing for the mixture/low speed screw or the idle screw. Could someone please help as I dont want to damage the engine.
Old 10-08-2002 | 08:20 PM
Bax
nellysinc,
The initial setting of the idle mixture needle is set with the carburetor opened to the full-throttle position (the engine's not running at this time!). There should be about a 4mm gap between the needle and the nozzle when you look into the venturi.
This is a rough, rich setting, and you'll work on the idle mixture after you've gotten the high-speed needle close to where you want it set.
We hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at this email address. (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions) Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Bill Baxter, Manager
Hobby Services
1610 Interstate Dr.
Champaign, IL 61822
USA
Phone: 217 398-0007
Fax: 217 398-7721
Email: [email protected]
Web: http://www.bestrc.com
