O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 1.40RX help
Old 12-11-2002 | 04:36 AM
Banned
Default OS 1.40RX help
I have a question about the OS 1.40RX. I have the non efi version. My question is I have the 1.40, a hatori header and a hatori pipe (these are 100% identical to the OS, I believe OS just put their name on it.) My question is, is this system pre-tuned? Where should the pipe be in relation to the header? directly against it or space? does the header need to be cut to get increase in rpm? i appreciate any info before I go cutting the pipe, and initial setup, thank you
Old 12-11-2002 | 03:51 PM
Bax
Cool,
Most tuned pipe systems really aren't pretuned. They may be close, but you'll still have to do some work.
Start out with about a 1/2-3/4 inch gap at the silicone joint. Start the engine, lean it to peak and tach it. Shorten by 1/8-1/4 inch. Start, lean, and tach again.
Keep doing the cycle until you get no change in RPM. Back the pipe out the amount you just shortened it and clamp it all down.
If you find that you need to trim the header, do it in 1/4 inch increments. You want to wind up with no more than about 1/4-3/8 inch gap in the silicone joiner. Too much gap will cause the joiner to pulse with the engine, and that will mess up the pipe's tuning.
If you change props or fuels, you'll have to re-tune the exhaust system.
Listen carefully to the model in flight, since you'll likely have to adjust the pipe system to account for RPM changes in flight.
