O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.S. FL 70 2-vent setup
Old 07-05-2006 | 07:18 PM
Default O.S. FL 70 2-vent setup
Mr. Baxter,
I am about to purchase the Surpass II 70 for my OMP Katana V46. I read this message where someone was going to install a tank with double vent setup, as to assure continous tank pressure during acrobatic activities. ( I hope I translated that correct).
Is there a certain brand tank you would recommend for such setup Sir??Is there a tank with such setup already installed or do I need to craft it together??
Thanks for your help Sir.....
Old 07-06-2006 | 10:07 AM
Bax
Default RE: O.S. FL 70 2-vent setup
For a tank with multiple vents, you'll likely find that the Sullivan tanks will be the most easily used. Other types of tanks have ports molded into them, but you can't route the tubing inside of the tank. Sullivan tanks can be easily modded because of the way they seal them.
