O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
temp anf fuel
Old 12-19-2006 | 05:49 PM
Default temp anf fuel
i think i will get temp gauge that will tell highest temp on last run does anyone know what degrees in far. on aos or vx 16 engine and do you think 20 % is safest to use for newbie/
Old 12-20-2006 | 11:58 AM
Bax
Default RE: temp anf fuel
First off, O.S. does not make a .16-size engine, and we'd not know what a "VX" is.
20% fuel is OK in an R/C car engine as long as it has enough oil and the engine's tuned correctly.
As for temps: It's not possible for us to give you an actual temperature or temperature range for your engine. The specific temperature is determined by too many factors. There is only one way to determine at what temperature your engine should be run. You have to run it first and then find out what temperature the engine reaches.
Make sure your engine is operating properly with the performance you expect. Use the exact setup every time...fuel, exhaust system, plug, measurement location, and so forth. If you change anything, the temperature will change. Once you have the engine running the way you want it. Take your measurement. This is your starting point. You will have to take measurements over time to find out how the weather affects it. As the air temperature and humidity change from day-to-day, the operating temperature will change. Eventually, you'll find a temperature range that you can work with.
Engine temperature is not an absolute number for setting your engine. It is only a guide, and can help alert you to potential problems. The only sure way to make sure your engine is running correctly is to see how it's running. An engine can be operating at "correct" temperatures, but not running well.
Finally, use any temperatures you read about, or people tell you, as rough information. The only useful numbers are the ones you actually measure when your engine is running correctly. If your engine is running correctly, then what you measure is correct, even if some else says it's too high or too low. Don't worry about the differences. Each engine is in a unique installation with a unique set of circumstances, so there can be wide variances in engine temperature.
Old 12-21-2006 | 05:32 PM
thanks you were very helpfull i better make sure what i have i orderd red cat tornado with 2 speed trsns and got asingls speed with tiawan engine a16 this is all a mess off ebay he orderd from factory and they drop ship and now no response from him owell thanks and merry vchristmas mike
