O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
91 surpass needle settings needed
Old 04-28-2007 | 07:13 PM
Crazy4Flight's Avatar
My Feedback: (540)
Default 91 surpass needle settings needed
I have a 91 surpass rann great last year,
this put it into new plane and starts ok but as i throttle up it backfires and spits the prop.
new OS F plug
new 15% fuel
fed it from clean hopper tank
backflushed carb with fuel
still back fires
oK took carb apart for cleaning
assembled with low end 3 turns out & high 3 turns out
and then opend them up some to get it to fire
still backfired & lost prop nuts
Correct starting needle settings needed or is it time to buy a Saito?
Old 04-28-2007 | 07:15 PM
My Feedback: (540)
Default RE: 91 surpass needle settings needed
SO FRA THIS ENGINE HAS CONSUMED:
1 SPINNER
2 PROPS
2 PROPNUT SETS
TOO MUCH OF MY TIME
Old 05-01-2007 | 01:49 PM
Bax
First off, get the carburetor set according to the instructions. These are the rough, "ballpark" starting positions. You then adjust from there as needed. If you don't have the instructions, then please send an email to the address below, and we can send you a set. We can't describe the setting because you need a diagram. It's in the instruction sheet.
