O.S. 1.20FS Engine Question
My Feedback: (124)
I just picked up a old but never run O.S. 1.20FS 4-stroke engine. I am pretty sure this is a pre-surpass engine. It just says 1.20 FS on the side of the engine. Also, the valve cover is two individual covers instead of the usual O.S. single cover. What is the difference between my engine and the surpass? Is my engine still a good, reliable, strong engine?
Tony
Tony
Your engine will run very nicely. However, it will not have the same peak RPM level as the FS-120 Surpass (with or without the pump) series. It should run in the mid-to-high-8,000's when propped with a 15 x 8 prop or so. The RPM will vary considerably, depending upon the brand of propeller.
If it needs parts, you'll have to scrounge for them. O.S. has not had parts for that engine for about two decades.
