onboard glow plug ingniter
GA
I am having problems with my inverted os 120 sur. III pumped engine after 3/4 of a gallon of omega 10%---20% lube fuel. It did wonderfully on the test stand upright. After I installed it in my Venus II, inverted, it bogs down on idle below 5000 rpm. I have read various threads on rcu, and I noticed you spoke of an onboard glow plug igniter.........As soon as I remove the glow driver from the engine it dies, it idles fine with driver attached. Where can I get an "onboard igniter", and is this problematic of a new os 4-stroke with less than 2 gallons of fuel run through it, unreliable idle.
RE: onboard glow plug ingniter
An onboard glowplug battery system is usually just a 1.5V battery with a micro switch. The switch is wired so that a servo will turn it on when the throttle goes below 1/3 or so. O.S. doesn't make one, but there are several different makers of these. Here's one we know about:
RAMP1350 50 IGNITER 1800 DRIVER/STR $49.95
Your hobby retailer can easily order one for you. There are others being made but we don't have info on them at hand. A search may find them for you.
