40la
MA
Am breaking in a new OS40la. Need to know recommended full throttle rpm,idle rpm. I am running 10% nitro with a 10-5 mas prop.
I plan to run 15%heli fuel a/break in. I am currently running a AX46 on that fuel.
thanks in advance
Fredsedno
thanks in advance
Fredsedno
Please make sure the fuel you use in your O.S. Max .40 LA contains castor oil in the lubrication. It's a plain-bearing engine that will benefit greatly from castor oil in the fuel.
As far as RPM is concerned, we use a 10 x 6 propeller and expect to see the engine turn in the mid-11,000's. Idle should be about 2,500-2,700 RPM.
