O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS.46FX
Old 07-18-2007 | 12:12 PM
My Feedback: (25)
Default OS.46FX
The needle valve mount on my.46 FX backplate is broken off. Will a .46 AX backplate fit? I'll install a Tower.46 rear needle valve assembly which has its own mounting bracket. A far less costly repair.
Roy Perry
Old 07-19-2007 | 09:45 AM
Bax
Default RE: OS.46FX
You will need to install a .46FX rear cover. The AX parts don't have the same bolt spacing, and the diameter of the inside of the crankcase is different between the engines.
