OS.91 4-stroke engine help needed
TX
I now have my engine starting, but running not as it should.
I have raised the fuel tank on my test stand to be about even with the spray bar in the carb?
I have a 13/8 prop on the engine.
Any suggestions, I appreciate the help so far.
Philip
Philip
Philip, it is had to follow you question. I am assuming that you ask another question about the engine, but this question is not appended to the first, nor is there a link to the other thread.
How is your engine not running as it should? Hove you gone through adjusting the needle valves, IE set the high speed mixture at full throttle for max RPM then back of by 500 rpm, then set throttle as slow as it will go and keep running and then lean the idle for max rpm at that threottle setting, then do both adjustments again.
All this assumes that you have a tach so you can see what is going on. If you don't have one, buy one or at least borrow on from a club member. A tach is an absolutely necessary for tuning a four stroke until you have a lot of experience with the engine.
Don
Don
TX
Hi Don, my first posting is just below this one about the OS .91.
I have now received the manual via email from the helpful moderator's website and am going to read it before I do any more "screw turning" because I believe the engine was pretty well dialed in before I got it.
I will locate a tach good idea Don.
Philip
Philip
