O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
.12 tz
Old 11-17-2007 | 02:14 PM
Default .12 tz
will the p3 plug run in this motor with 30% nitro.
Old 11-19-2007 | 10:51 AM
Bax
Default RE: .12 tz
No, the P3 is a "hot" plug, which means it's for "cold" fuels. You want to run an A5 or R5 plug with high nitro. You may also need to add an additional cylinder head gasket if the engine tends to detonate.
