O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
FS 120 Supercharged HELP
Old 12-11-2007 | 09:57 PM
Default FS 120 Supercharged HELP
Hello,
Many years ago I had sent a supercharged 120 in for service, to find out after propper break in, I mis-used the engine, and had it sent back to me. I received the engine in pieces, and after these years cant find the impellor assy for the pump. I cant find any parts layout for this piece, but it seems its a single impellor driven by a pin or ball on the shaft driven by the crank. Any help on a diagram and or parts available would be great. Thank you in advance for your response.
-Andy
[email protected]
Old 12-12-2007 | 10:52 AM
Bax
Default RE: FS 120 Supercharged HELP
If parts for your engine are lost, we'd not have any. The engine's been out of production long enough that parts specific to it are no longer available from us or O.S., in Japan.
The pump was a gear-type pump, and one of the gears was on a shaft and tied to the shaft with a very small steel ball. It worked similar to a Woodruff Key. We'd not have that part. In fact, we never did. Repairs to the pump and regulator system were performed only at the O.S. Factory. Also, once the supercharger had been disassembled, you needed to use a special sealing compound on the housing when it was closed to make sure it operated properly with no air leaks.
If you send an email to the address below, we'll be glad to see if we can locate an exploded diagram of the supercharger.
