O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 70 4 Stroke
Old 04-10-2003 | 07:47 PM
Default OS 70 4 Stroke
I checked my engine with the needle valve completely closed (lean), and hooked a piece of gas line to the intake of the carb.
I can blow through it.
What is my next step to correct this.
The needle valve is fine.
I tried a new one, and it does the same thing.
I talked to you on this in another thread, and you told me what the problem was now I wonder if there is a way to correct?
Bing
Old 04-11-2003 | 01:25 PM
Bax
Bing,
From your description, it sounds like the only solution to your difficulty would be to replace the carburetor body.
