O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
FSa-56 fuel
Old 03-10-2008 | 06:41 AM
Default FSa-56 fuel
The OS FSa-56 says 18% lube, is it ok if its a blend between synthetic and degummed castor? Or will this engine have problems with the castor?
Old 03-10-2008 | 10:52 AM
Bax
Default RE: FSa-56 fuel
A synthetic/castor blend fuel is OK. It will need to have some carbon removed from time-to-time.
Old 03-11-2008 | 02:02 AM
I know how to clean 2c engines using kerosine or boiling and adding some detergent after removing rings etc..., how will i clean it from a 4c?
Old 03-11-2008 | 09:52 AM
Bax
To clean a four-stroke engine, you use the same methods that you use to clean a two-stroke engine.
Old 03-14-2008 | 01:04 AM
Would thre be a problem using a high oil quantity fuel like 20% castor / sinthetic blend in this engine? or is that just too much oil for a 4 c?
Old 03-14-2008 | 09:55 AM
Bax
It's not "too much" oil. You'll just wind up adjusting the needles appropriately.
