O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
55 AX Mid Range
Old 05-19-2008 | 02:32 AM
lomcevek1's Avatar
Default 55 AX Mid Range
Hello
I have a 55 AX on a 3D Profile. I am running wildcat 15% Nitro with 18% castor syn blend. The engine has about 1 hour of runtime, starts wonderfully, never run lean, idles great and makes GOBS of power with an APC 12.25 -3.75. I am also running a MACS pipe.
The problem that I am having is that the midrange is nonexistant. I have a good transition to full throttle, but there is a deadband which is I guess is the best way to describe it.
Any suggestions ??
Old 05-19-2008 | 10:26 AM
Bax
Default RE: 55 AX Mid Range
We'd suggest that the midrange is a problem because you have a too-high top-end RPM. The prop sounds a bit small. Check the peak RPM on the ground and see what you have. You may need to bring the RPM down a bit.
Now, it's normal for the midrange to have a "flat" spot, where you see little RPM change when you move the stick, but you should still be able to move the stick from low to high without much engine problems.
Old 05-19-2008 | 12:46 PM
lomcevek1's Avatar
I have also run the APC 13-4W and a XOAR 13-4 Same thing for each one. A little research from some others running this is suggesting just put the stock muffler back on.
The deadrand is REALLY big almost to the point I was thinking it was a throttle rigging issue. But checked it and it's linier.
I will try a bigger prop and tach it this time and get back to you here. Might be a day or two though.
