engine mount specs
We still don't know what "specs" you are looking for. The size of engine mounts or the measurements of an engine that's mounted? If it's of an engine that's mounted, then the mount you use can determine a lot. As far as the O.S. engine mounts, some were measured when the tech notes were made. We'd need to know which particular mount. We don't have a form/paper with all the info printed on it.
so i know the overall length from firewall to prop
as os mounts are pre drilled and taped none ajustable
to know before you bye would help
We don't have such specs. O.S. only sells the mounts. Some have been measured by our staff as to where the mounting holes are located on the mount, and you'd have to go from there, relating those distances to the engine. We'd have to know the specific mount you're looking for, we don't have a chart with all of them on it.
