O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Need to know about compression
Old 06-24-2003 | 02:55 AM
Default Need to know about compression
with out sounding stupid, what is the fastest way to check if an engine has good comression. I am not sure how to tell. ANY HELP WOULD BE GREATLY APPRECIATED
Thanks: Steve
Old 06-24-2003 | 01:27 PM
Bax
Steve,
Generally, if the engine will run well, deliver good power, and have a good idle and acceleration, the compression is good. When the compression seal starts to wear out, the idle and acceleration are the first things to go bad, even if the engine still runs well at full throttle.
We don't have any particular compression numbers for you, and O.S. doesn't have a specification for compression.
