2 stroke carbs in general
My Feedback: (8)
Bax,
Is there a good resource that explains the OS carbs, mainly the AX carbs?
I understand pretty well how to tune them, and what adjusting each screw does to the performance of the engine. Truthfully I don't understand how the idle mix screw physically works. I know the HSN is basically like an orifice meter and allows for fine adjustment of the total amount of fuel that can pass by opening/closing the passage. I feel like the idle mix screw does something with spacing in the carb rotor, maybe working with the opening in the carb rotor to adjust the amount of suction on the fuel system?
It all depends upon which carburetor you're talking about, but if the carburetor rotor moves in and out when you throttle up and down, then what happens is that the idle adjustment changes the area of the fuel outlet inside the carb venturi. Some carbs have an actual idle needle, and the taper of the needle does the job. Other carbs have a slot that is opened or closed by a sliding tube when the throttle is opened or closed. Some of the high-end carburetors have a specially-shaped slot that exposes more or less area as the throttle opens and closed.
In all cases, the adjustment of the idle mixture adjusts how much fuel is permitted to flow at idle. The shape of the needle or the shape of the slot determines how the mixture changes as the throttle is opened or closed.\
