O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
another os 160 fx question
Old 07-09-2003 | 12:35 AM
LeeL's Avatar
Default another os 160 fx question
Hi Bax;
I have another question for you. I took your advice and changed props on my engine I am now running an 18x10 Master airscrew scimitar wooden prop. and just to be on the safe side I changed my tank to a 3 line set up with a large size clunk on large diam. fuel tubing all the way thru for the fuel supply line. The problem is now I only max out rpm at 5200 and there is no noticeable change when I try to adjust the high end needle and my transition is still rough. at all throttle positions the engine doesn't miss a beat it just doesn't want to transition from low rpm to high any ideas on what I should do now?
Old 07-09-2003 | 01:34 PM
Bax
Lee,
It's hard to say what the problem may be. With an APC 18 x 10, we can turn the O.S. Max 1.60 FX w/stock muffler at 7,900 RPM. You're turning 2,700 RPM lower. The engine still may not be getting enough fuel.
Try opening the idle needle a LOT and resetting the high-speed needle. You'll likely have to start the engine at part throttle because the idle mixture will be too rich to allow any kind of decent idle. Get the top-end set first and then try the bottom end.
If all else fails, and you can't get any better performance on a test stand, then there may be more wrong than we can diagnose through some emails, and the engine may need to get into the shop.
Old 07-09-2003 | 03:16 PM
My Feedback: (31)
how is the compression the motor may haqve had a lean run and now is scorched...
Old 07-26-2003 | 10:29 PM
LeeL's Avatar
Hi Bax. Well problem is solved, the 18x10 is turning 7800 rpm I don't know how much thrust the engine is developing yet, but by the way my plane is moving I can tell it's better than before. I found that some trash had gotten into the carb and was creating a small restriction that would starve the engine of fuel. Cleaned it out and now all I can say is wow what an engine. And it transitions perfectly at the factory settings. Thanks for all your help.
Old 07-28-2003 | 03:24 PM
Bax
Glad to hear that you're problem's solved! Trash'll do it every time!
