OS FS-120 Surpass-II with a pump
I bought this engine nib at a swap meet but it doesn't have a manual.Is a manual available?Where might I get one?Is there any way to tell how old this engine is?The box it came in is black.Thank You---Mike
RE: OS FS-120 Surpass-II with a pump
NY
Could I also have a copy of the FS-120 Surpass II instructions? I bought an engine at our last local aution and have no instruction. I have been able to identify it as a Surpass II based on review of past forum discussions. I have not yet run the motor and would like to know the recommended break-in, prop size, so on and so on. My email is [email protected] THANKS
Bax,
I have a brand new FS120 Surpass II w/pump that still new in box, recently I am trying to install the engine on my new Sig Spacewalker II, but I lost all instruction sheet. Please email me a copy of the instruction sheet if possible. Thank you!
My email address is [email protected]
My Feedback: (35)
ID
I also am requesting that you send a copy of instructions for a Surpass II 1.20. Hopefully, it will tell me how to plump the tank!
[email protected]
Thanks, Bill
[email protected]
Thanks, Bill
My Feedback: (9)
Hi Bax. I also have recently acquired an OS 120 Surpass II with pump. Can I please have a copy of the instructions?? Pretty please with sugar on top.....
[email protected]
Sean
[email protected]
Sean
MN
I know this sounds redundant, but I have just purchased the same engine w/o a manual and would appreciate the instructions.
[email protected]
Thank you
[email protected]
Thank you
My Feedback: (42)
NC
HI,
my story is that a club member want's me to fix his OS FS 120 Surpass 11 with Pump and a C13 carburetor and he has no manual,
I would be gratfull if you could send me any kind of manual for this engine as well as any info on locating parts for the engine and especialy the carb and pump.
I am having a surging problem at high speed and not sure whats causing this problem at this time,
the engine is in great codition the pump has lots of pessure and every thing looks good, I could have a simple problem that I cant notice with this engine since Im not familiar with this model,
Any help would be greatly appriciated.
Many Thanks
[email protected]
Many Thanks
[email protected]
Bosco,
Manual sent.
Surging is caused by a too-rich high-speed needle setting. Please see the following link for carb setting of pumped engines:
http://www.osengines.com/faq/faq-pumped.html
Manual sent.
TX
I'm trying to rebuild my C13 carb and was able to get all the orings on the C13 parts illustrated breakdown, but there are 3 o-rings under the diaphram (just above the choke valve) that are not shown. Two of the o-rings are very small ~4mm OD. I talked with hobby services and they were unable to help. Is there anyway to find out what size these are and material? A place to get new ones? If not what about using another carb?
My Feedback: (23)
MI
I too need a manual for 120 II where can I get one. email is [email protected]
OH
I have just acquired the same engine and you guessed it, no manual.
My tank setup looks like a plumber's nightmare.
I have a line to the pump, a line out of the pump back to the tank and a line from the pump to the carb. These are all marked "in" "out" and "return or R" if I remember correctly.There is a line from the crankcase to the intake manifold(which was on the engine when I got it) and a vent line from the tank. This was plumbed by committee so I have no idea if it is correct. I ran the engine but couldn't get it to lean out. Prop was an APC 16 x 7 if that makes a difference. Maybe a little much?
Any thoughts? I can close the needle and cannot blow through the line. No leakage.
Thanks in advance
Joe
Thanks in advance
Joe
It sounds like the system is plumbed correctly. If your engine cannot be leaned, then it's possible that the needle seat in the carburetor is damaged. That will require the replacement of the carburetor body and needle valve. Unfortunately, the #C-13 carburetor for your engine is no longer available. You'd have to locate one through one of the retailers who specialize in finding parts for the engine collectors' market.
a friend of mine was "serving" his OS 120 surpass when the camshaft broke loose from its position With no clue about timing he cannot replace it. He told me that there a "t" mark on the crank that supposedly has to be for timing the camshaft, the question is how ,Could you plesae give me some directions? He is also asking me (i`m the expert, you know) how could he polish the valve seats.
regards
jose brown
Antofagasta
Chile
regards
jose brown
Antofagasta
Chile
Here's how to set the timing:
http://www.osengines.com/faq/product-faq.html#q15
For the valves, we use toothpaste to clean them up a bit. There is very little metal so if the valves fit very badly, you will need to replace the valves and cylinder head.
