bgx 3500
RE: bgx 3500
You'll have to take it apart to check. Low compression is usually a problem. If the engine run well, though, from idle to top end, then don't worry about it. If you have a good idle, good top end, and good throttle response, then the compression is OK. Dry engines will always have a low compression feel. You need fuel in the engine because the oil helps seal it when you're turning the engine by hand.
