O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Os engine suggestion
Old 08-06-2010 | 11:11 AM
Default Os engine suggestion
I am planning a OS engine purchase and need suggestions. What is the best way to run my new engine on a airboat with a pusher configuration. Will the engine run too hot?
Thanks/
Old 08-09-2010 | 09:23 AM
Bax
Default RE: Os engine suggestion
If you make sure any cooling air can flow through the fins of the cylinder and cylinder head, you'll get OK cooling. On an airboat, with a pusher prop, just make sure the cylinder and head are exposed, it should cool well.
