OS 46 only starts with Starter
I have an OS 46 FX . Itwill only start with a starter .
Even if we Use a Chicken Stick to start , itwill not happen . What could the possible remedy be for this . Regards. Arjun |
Arjun,
how old is the engine? has it always started this way? is it fully broken in? |
<<POST DELETED BY MODERATOR. Please refrain from answering other modeler's questions in the "Ask the Manufacturer's" forums. Thank you. >>
WEll this engine is nearly 8 months old . Yes its beeen broken a
long tiem ago. It used to Start with a flcik , but know , will not strart without a Starter . Would reqeust a cure for this . Regards. Arjun |
It sounds like the engine is losing compression, possibly due to a lean run, bad fuel, or a manufacturing defect. I would send it for service.
This engine was purchased in DUbai .
Do I jsut give it for service here . Regards. Arjun PS : The engine otherwise runs perfec , only starting has to be done with the strater . |
Ar,
Yes work with your distributor in your country. |
