RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   91 FX (https://www.rcuniverse.com/forum/o-s-engines-support-133/2849139-91-fx.html)
2amped 04-06-2005 11:33 AM
91 FX
I just purchased a 91 FX. I have not run it yet. After putting on a prop I tuned it over as if I was starting it by hand (without a glow pug attached). When the engine bounces back off the compression it has a ticking noise as if the connecting rod is tapping the inside of the crankcase. Is this ticking sound normal? My 46 FX makes no such noise.
Bax 04-07-2005 09:47 AM
RE: 91 FX
The 'ticking' noise you hear is most likely the ring tapping against the ports in the cylinder liner. It's common with large engines. You'd not likely hear a rod because the oil would cushion it.
