RCU Forums
-   O.S. Engines Support (https://www.rcuniverse.com/forum/o-s-engines-support-133/)
-   -   1.60 needle settings (https://www.rcuniverse.com/forum/o-s-engines-support-133/3116327-1-60-needle-settings.html)
SunShyne 06-27-2005 10:43 PM
Greetings Bill
I got a new #60f carb back on my 160 and tossed the Perry carb off of it. I took the carb out of the package and bolted it right on. Is the needle already set for a factory setting or should I adjust it now? Im wondering how many turns out it should be?
Also in your opinion what has been the consensus for a good low end setting after the engine has broken in?
thanks
matt
Bax 06-28-2005 11:35 AM
RE: 1.60 needle settings
The carb instructions are with the engine instructions. You can download them here:
http://www.osengines.com/manuals/160fx-ring-manual.pdf
As far as the "correct" setting is concerned, it depends upon fuel and propeller. You set the idle mixture where you get a good idle and acceleration. We don't have any "number of turns" to give you. Usually, though, it's not far from the factory setting.
